92-96 prelude shift assembly
    Will a 92-96 prelude shift assembly work with 90-93 Accord shift linkage?
    I tried using a 5th gen shifter with 4th gen shift assembly and linkage and one of the holes on end of the linkage was to small for the 5th shifter I thought they were all interchangable..
    Yes it will work, and it works bueatifully : )
    You will have to bend, well more kinda just slide one of the shift linkages because the Prelude shifter has the link a little diferently, and then you can order the OBX short throw and that works nice. The diff with the preludes and the accord is mainly with prelude shifter, it wont go that far over to first gear, so if you want you can customize the console and put some switches there, it would look bamf!
    H22a they always smile before Vtec....
    VIDEO WATCH ME!!!!
    My Members Ride Check It Out
      so it will bolt right up to the car and the linkage will attach to the shifter fine...
        Yea
        Also those 4 bolts that hold the assmble down to the frame are kinda of a bitch because it doesnt match up perfectly, its a little off, so Put the 4 bolts in, but dont tighten them on by one, just get them inistialy in then crank them down, and try not to strip em, and putting the accord shift linkage into that mount is also a bitch. But its worth it.
        VIDEO WATCH ME!!!!
          Hell yea it works buetifuly. I have it installed in my car right now!!!! Thankx to mr. 92BLACKEX. he put it in cause i was lazy, and i had just finished puttin in my indash dvd.
          92ex coupe h22
          93 240sx with silvia front end (kadet in the works)
          http://www.cb7tuner.com/vbb/showthre...=1#post1894990
            Its a sexy setup compared to his last shifter out of a 5th gen, it was like a fucking TRUCK shifter, and the prelude shifter and the in dash dvd player are SEXY as HELL
            VIDEO WATCH ME!!!!
