Hi guys,
I have a leaking coolant by the back of the engine area that drips down to the pipe causing a smoking engine bay.
It's hard to see where it's at but I can see that it's somewhere around the oil filter.
It's not that big of a puddle under the car but enough to notice it. And it's not by the water pump area where
others have leaked the coolant.
I looked at the Haynes but no info found and looked at the service manual diagram and notice that there are
a lot of hoses that are connected around where thermo stat is.
I showed the leak to the mechanic and he tells me that it's a regulator pipe that needs to be replaced
which will cost me around $200.00. He tells me that the part will cost $5.00 but it's labor intense since he
have to take off a lot of things. Does this sound right?
Thanks,
Thanks,
