Please help: Electrical prob seat belts not working
    ok both my seat belts were working fine and both went out at once, also at this same time my door beeper dont work, seat belt light doesn't light up, now heres whats weird the clock also doesn't work but when you press the cover on the clock it comes on until you release it, also it always reads 1:00, its like it had some sort of short.
    check the fuses under the hood
    Members Ride
      both fuses are good. to be honest heres what I think happined when I bought the car someone ripped the stereo out and the wires were exposed I went to the junkyard and cut out the stock connector and wires out of another accord so I could put in a stock stereo and when I grabed the other wires I think something sparked in my car as the wires were bare.
        so did the new radio work? does your cig lighter work? you might have toasted the seatbelt brain which is located under the passenger seat or it could be something els.. check everything from the fuses and relays..
          cig lighter still works and radio turns on, unfortunatly the radio i have came with the car in the trunk is from a 95 integra and needs a code so it doesn't work but it does turn on and it does beep. I just would think that the beeper, clock, and seatbelts would be shorted by one thing?
            your clock is toast, it #$^% up.... my brother civic clock does the same thing, lits up when u hold the buton and always on 1;oo......when u spark the wires, u toast the clock....well, hope that 1 lesser problem to solve
              Fixed it just a 7.5 amp fuse in the engine compartment man do I feel stupid, thanks, btw can anyone here get me a code for a acura radio? its in my accord and just says code accross the screen.
                I believe you have to have the VIN# for the car it came out of to get the code. The dealer can get the code if you have the VIN#.
                The 90 Accord 4DR Sedan my son and I are building.
