Power Steering Trouble
    Recently my power steering on my 91 coupe has been going out. This only happens every so often and only on turns. I checked my power steering fluid and its fine. There is no leak that I can see. It also makes noise like a pigeon when I turn sometimes also. Any idea whats wrong?
    91 Coupe-Under Construction
    gotta be your pump....cus when you turn your wheels your pump works a bit harder to pump the fluid to one side vice versa etc....i really do belive it syour pump i mean steering power pump
      Noise like a pigeon? I know this is a dumb question but have you checked the tension on the belt? Sounds like a belt slipping to me.
      The 90 Accord 4DR Sedan my son and I are building.
        X2
          the tension is fine.... what i mean be sounds like a piegon is when i turn the wheel, i hear a noise that sounds like a piegon
