can this be the problem? cv boot?
    too lazy to write again
    http://forums.montrealracing.com/sho...58#post4061458
    cccheaaaa
    Accord Nation
    92 accord sold, 91 accord ex-r still alive
    240sx for that dorifto action comming soon
    Originally posted by NightRyder91
    fux it
    Originally posted by Masamune
    Accord Vehicle Info:
    1993 Honda Accord SE Auto
    Symptom(s):
    Car makes a clicking noise while turning in either direction. *Note* This can happen to any model/trim.
    Cause(s):
    After looking underneath my car, I noticed that the boot was cracked wide open and metal was being exposed to the elements. All grease that was in the boot was gone, and the CV joint was rusting.
    Price(s):
    $70 from autozone w/ lifetime warranty. No labor cost, I did it myself
    Solution:
    The CV joint needs to be replaced. Apparently it's easier to change the whole axle out though, and cheaper too. Jack car up, remove wheel, remove axle nut, slide axle out (the top boot part that goes into the tranny may stick) slide axle back in and put said parts back in place. First time will take you an hour, after that it's a 20 min. job tops.
    I Hope this will be read enough to decrease the post count about this.
    cccheaaaa
    Accord Nation
      the cv boot is the initial problem until the grease is replaced with dirt and water. You need to replace your cv joint (that means the whole axle)
