Pass. Window
    Pass. Window
    The passenger side window is real slow going down, but rolls up at normal speed. possible problems? havent had the time to take it apart bc of work and all.
    -My Baby-
    might be the motor
    93 Accord LX Sedan (sold)
      i have the same thing but its on the drivers side. It should be the motor
        try to grease sliding surfaces of the window regulator and check glass adjustment and also check the glass run channel for damage
          spray silicone in the run channels all the way around the perimeter of the window. later.
          Avoiding dirt at all costs
            Damn G, we are thinking the same things today (great minds think alike) you just beat me to the answer.
              i got sam prob only my shit only goes down like 6 inches...put a new motor and everything...ill try the silly-cone and check my runs, etc.
              Originally posted by Jarrett
                Sounds like your tracks may be bent or out of alignment if it only moves 6 inches down. I have gotten bad motors new though too.
                The 90 Accord 4DR Sedan my son and I are building.
                  run channels
                  im pretty sure its the run channels if its not going down anymore than 6 inches. this happened on my coupe. i just removed the door panel and saw the run channel was all messed up as the window kept shoving it down and compressinging it everytime i rolled it down. just take the panel off and run your finger through it to straighten out the channel and for extra speedy up and downs just spray in some silicone. later
