Gas leaking
    its gas in english
      Shure glad I live in the south. No rust here. For that amount of money i would run my own line to the engine, fuel hose is cheap.
      The 90 Accord 4DR Sedan my son and I are building.
        Yeah at this point, this seems to be mostly an extreme northern issue.
        '92 Accord LX Sedan--Bordeaux Red Pearl --OEM--279k Daily Driver
        EX Lip & Alpine OEM single CD Player. No more useless pocket!
          if there is a hole on the gas tank you can JB weld it (depending on the hole). I did mine
          Follow me on IG: @jdm_inspired
          93 'til infinity
            i had the exact same problem. my line was rusty n started leaking so i just put a rubber hose over it and its been fine ever since.
            Hold On Not Done Accelerating
            Had One Never Did Again
              Originally posted by croc-note
              My car is park since Friday and 10minute ago I take it to go to the restaurant and start the car, changing my cd and then that smell of gas. I shift in 1st and slowly advance the car, and I see a huge spot in my parking. I put the car back at the same place and check near the fuel tank and the gas is leaking a lot. ( Ilost like 1/8 of my tank in 5 min).
              My car was ok friday and take it today for the first time since and is leaking ??
              What to check ??? Will I need a new gas tank ??? How much does it cost ??....
              THX
              take it to a shop and have them check it, should be free then go from their.
                I hope your car well soon guy.....
                Honda Accord CB from Bangkok..,Thailand,Hi all guys....
                My msn :
                  My car is now Ok for the gas leaking... The gas line was disconnect from the tank :P
                    Just started having this problem this week, Gas smell, dripping, right behind the rear/driver side tire. I removed that protective cover from over the pipes, and saw the leak right away.
                    It is the bigger of the 3 pipes that is leaking, the one that has the big bracket attached to the chassis and fittings going through it, not sure if this is the main feed line or what???. Anyway, I wiggled it a little and it broke right off(corrosion). Its the pipe that goes up to the engine that is broke not the rubber hose that goes to the fuel tank.
                    How much work would it be to replace the whole pipe?, and does anyone have any ways of fixing it without replacing the whole steel pipe? It looks like I may be able to use rubber hose to splice it back together, but I'm not sure about the pressure in that pipe???. Plus I'm worried about getting rust and chunks in the fuel system.
                    Any advice would be appreciated. thank-you
