Gas leaking
    Gas leaking
    My car is park since Friday and 10minute ago I take it to go to the restaurant and start the car, changing my cd and then that smell of gas. I shift in 1st and slowly advance the car, and I see a huge spot in my parking. I put the car back at the same place and check near the fuel tank and the gas is leaking a lot. ( Ilost like 1/8 of my tank in 5 min).
    My car was ok friday and take it today for the first time since and is leaking ??
    What to check ??? Will I need a new gas tank ??? How much does it cost ??....
    THX
    THX
    if you can see the hole and it's not rusted out and is just a pin hole of some kind, then yeah, they can fix it.........they'll take it off, fill it up with water, weld it and then call it a day.........may be cheaper/easier to get a used tank though.....i'd replace the pump while i'm in there as well, unless it's relatively new
    not the most impossible job, but helps to be on a rack and/or have help
      well if u saw gas leaking from the tank im gunna go ahead and say u need a new gas tank, could be coming from a hose fitting near by tho
        The drain plug isnt losse at all?
        H22a they always smile before Vtec....
        VIDEO WATCH ME!!!!
        My Members Ride Check It Out
          The gas is comming from the driver side. It's like a protector with two hole and the gas from there.
            yeah take off that protective plastic piece, and you will see the pressure feed return lines, they tend to rust out where they are attached to the chassis.
              I'm gonna check that tommorow because it's to dark now, but i try to touch and i think that come from an hose under that protective piece.
              Hope it's not the tank..... no $$$$ for that now :P
                my fuel line started leaking it cost like 100 for them to fix it and then liek a months or 2 ago it staretd leaking again so they fixed it for free
                My Members Ride Page
                  It's my fuel line... This morning I jack the car and start to remove the guard and some of the line fell on the ground (like 6inch long).
                  Now I can't take my car to go buy a new gas line... can go to a shop to get it repair.... i'll need to get it tow :\ or is this really hard to change?????
                    i'd try to fix it yourself, just take precautions not to blow yourself up. later.
                    Avoiding dirt at all costs
                      Yea man work in the day with that shit...no drop lights no ciggerettes or stupid friends ...be very aware of your surroundings....i dread having to work on that shit but if you just take your obvious precautions youll be a ok!
                        I've just call to a Honda dealership and they charge me 129.99$ for the gas line.... And the guy told me that take about 4hours to change it ( ouch) at 75$ an hour :\ Plus I need to get the car tow to the honda dealership (100$) I tell him i will call back later..
                        So I call to a place that I can have some good and cheap part... 70$ for the line... and he told me about 2h30min to change it (60$/hour).....
                        After that, i've got to little mechanic shop near my house, and the guy tell me he can only change what is not good on the line ( 60$/hour) + 8$/feet of line. And I don't need to get my car tow because it's like 700feet of my house...
                        I'm going tommorow morning.... I'll update you for the price I paid...
                        P.S. Gas or Gaz (in english) or the 2 is ok ???
                          That happened to me, the pipes rust easily, and wher eit and the rubber ose connected was leaking, my mechanic put another clamp onit, I can still smell gas but there is no sign of leaking. On my other car the gas pipe is really rusted, I want to replace it before that too get a huge hole in it. Take a look at it though before going to a mechanic, might be able to fix it yourself. Take off the back tire, then the plastic shield, you'll be ale to see the piping.
                          Sean-Dinner.com
                            all they did with mine is patch it and reclamp it its been fine no gas smell or anything
                              my first leak they just did the clamp method, but my most recent leak sounds like the problem this guy was having, its where the hardline fitting bolts to the chassis, you need to replace the whole line. Mine cost 500+
