90 accord with 97 h22a help
    Hello everyone
    The swap went good until it was all done and here are some problems we are having the CEL is on and NO VTEC.The code that came up was for the air intake temp sensor and i got a new one and put in on, the CEL is still on. Also anyone else have problems like this when they put a 97 jdm h22a in a 90 accord or what ever. if you can help me i will be so happy thanks.
    for your code after installing it did you reset the ecu by pulling the 7.5 amp back up fuse?
    Members Ride
      if u got a cel....ur vtec will not kick.....like they say, did u reset the ecu??? did u damage the wire for the plug while u put it in....what computer did u use??? a little more info about what parts u use....maybe some can help then
        isnt 97 obd2? our cars are obd1 wouldnt that be an issue as well?
        My Members Ride Thread
        You have to think outside the box to get IN the box!
          he could have used the h22 harness, or he could have converted.
            ok i just tryed the 7.5 amp fuse thing and the light came right back on in like 2 sec. i have the option to sell my car and get a civic SI if i cant figure this thing out.
              what code is coming up now? do you know that?
              spin city
                are u getting any signal from the ecu to the plug for the temp air sensor??? what ecu are you running??? did u mess withthe harness???
                  i am takeing it to a shop next week for them to run test and seewhats wrong
