starting
    starting
    i have no clue what this problem is... the car will start up copmletely and then just shut off right away and then i gotta wait a few minutes for the computer to reset then itll start up fine .. but what could this be? main relay?
    ~howz da twig n giggleberries~
    hmm it could be the main relay
      WHen does it happen? If it still happens in cool weather could be your ignition switch. It wouldnt hurt to pull out the main relay and resolder it also. But describe the conditions when it doesnt start up or cut off.
        The actual ignition switch, or the ignition lock cylinder?
        Are either of these a problem with this generation of Accords?
          like said above, if its in hot weather then main relay, if in cool weather it could be the ignition switch itself
          Members Ride
            ok itll start go to like 600 rpm real fast and just shutdown.. in hot weather cold i didnt have problems
