i am in the process of changing the forged high compression pistons to forged low pistons,does my h22a1 block need to be blueprinted again or kind the pistons be changed and block assembled again?this work is in my 92 accord wagon.the head is gettin a stage 3 head package.
high vs low compression pistons
Blueprinted again? If your gonna run high boost you need to sleeve the block. This topic has been covered a lot of times already.
It can be changed but lower comp might allow you to run slightly higher boost levels but sleeving the block is still safer since h22a sleeves are like the sleeves in the f22a.
You can throw in type s pistons without resleeving and give you 11:1 compression so the answer is no. Depends on what type of work he did to the motor. If the block is already sleeved then your set.
