price of TCU automatic transmission???
    for those that have replaced them, how much did you pay???
    i think mine is shot
    chris<pixelmonkey>
    there were blanks in that gun!
    Try running to your local junkyard and gettin a quote I dunno if they sell em on ebay but you can check.
      looking on ebay right now, and will be contacted the honda salvage place tomorrow.
      looks like anywhere from 60 to 140 on ebay
      but a part of me still thinks i have an electrical gremlin somewhere. this being the reason for the e-fan running for 15 minutes after every time i turn off the car, the stero not working, and now this.
      chris<pixelmonkey>
        The fan is supposed to run after, it was designed that way by honda to cool the car down. And what makes you 'think' the tcu is gone? If you car shifts at all it's still working. If your speedometer is not working it's probably your speed sensor, which is on the back of the transmission itself. Let us know exactly what symptoms your car is having and we can help you better figure out what might be your problem and save you from buying parts you don't need.
        My 91 Accord F22B DOHC MR
        My 1996 Civic Ex H23A VTEC MR
          you may also have a short/shorts somewhere in your wiring. I had a number because of my car being in an accident before I got it and crappy re-install of whatever they did before to get it running again. If your car is acting up randomly ie radio, speedometer on and off, and possibly tach/ whole dash, it may be a major ground isn't working right. Had my radio and everything acting up till my shop finally found the ground messed up. Btw it's not the ground that directly comes off the battery it was something else so might need a shop to look at it. Might WANT a shop too look at it as my ground cause a fire on the throttle cable rubber housing and I had to call the fire dept and have them hose under my hood... not fun cleaning water out of the carpet...
