Can someone tell me what this sound :P
    http://s88.photobucket.com/albums/k1...ent=moteur.flv
    Ok the sound is not really great but I hope someone can help me. THX
    sounds like the motor is running. It really doesnt sound different than normal, unless the sounds are really loud or something, but no idea from that video.
    has it started to run differently from before or what? That ringing type of sound is the intake.
    You may need a valve adjustment. Our cars/engines are a little bit loud.
      get your valves ajusted
        That small ticking it normal, like 92turboaccord said try a valve adjustment(Check your oil) mine is so quiet after i did my valve adjustment.
          If you're talking about the ticking then yes, valve adjustments. If you're talking about the growl when revving up, it's the crankcase building and releasing pressure. Other than that, it sounds normal.
          Vouches: Honda-tech (my user name is Unidentified) and on here: J-SpecCB4, G-Wagon, Onyx10, Grumpys93, Ilikebigbutts, Koffin, F2291cb7, BadgerType, Cb7GHOST, 93a-lude, Driftspec310 or Accordex92.
          I will not ship to Military Boxes because it's a Pain in my ASS!!!
            Well I dont mean to scare you , BUT are u talkin about the whirring sound , cause to me sounds a little like there is no oil getting up to the top of the motor if anything , but it could be just the video source making that whirring sound other than that the tics and all that are normal and if i was you have somone adjust valves as well as make sure your getting oil circulation ,
            good luck
            -Sean- Noxidea
            Fore Sale" My Ride "Best Time To Date 14.9 @ 94 MPH ...
              hmmm listened a few more times I dont know seems like it could also be one of the pully's making that whirring sound ... check those out and maybe throw some PBR or WD on em and see if it helps .... good luck man
                He only do that whirring sound when hot and if i push the gas pedal just a bit (to rev the engine at like 1000 rpm) the engine dosen't make that sound.
                  liek the guys above said, that whinning sound is the intake.. dont want that sound? put the stock intake back..
                  1996 Honda Civic LX 2009-2012
                  2012 Kia Optima LX 2012-2013
                    theres 3 different sounds there, the vavles, the intake and then the wurring sound that isnt the intake, I have no idea what it is tho
                    My Members Ride Page
                      Could this be my timing belt???
                      to make a short story, In july I change my alternator...but when I put the new one back i lost a bolt that I never found... not on the ground, We searsh with a magnet and no bolt.... Since that time there the sound... could the bolt have enter somewhere in the engine ?????
                        that whoosh sound is the intake, that ticking is the valves, and that other noice might be one of ur belts, good luck
                          That weird whining sound is not your intake. It's the tension on your timing belt. Mine is doing the exact same thing, and it's happened to me before. I had one guy do my t-belt and it was really loud like yours. Took it to the Honda place, and they said that it was amazing that the thing hadn't snapped yet it was so tight. Mine's doing the exact same thing, and I know for sure that it's your timing belt. It's supposedly easy to fix though, I just haven't gotten around to it. Do a search, and you should pull up a thread from not too long ago where I asked how to do this.
                          Hope I helped.
