14b turbo
    14b turbo
    Hey guys and gals
    I have a 14b turbo but i dunno which holes are used for coolant n which ones for the oil feed line. Also when i bolt this thing up do i need the O2 on the turbo dump pipe or do i juss used a bung plug? Please if u cud held me out, help will be greatly appreciated. thanks
    Justin Peralta
    well, if you only have one o2 sensor, then its going to be wideband and i wouldnt put it that close to the turbo, they reccommend at least 24" downstream of the engine so the heat doesnt kill it. The two on the side are coolant lines, top and bottom are oil feed and drain, search for your shit its been answered all over.
      yeah ive tried searchin it, but i ges i type in the wrong crap cuz the serches give me sum different crap. if the only o2 sensor is the wideband, then theres no use of the stock O2 then, so do i juss disconnect it then?
      Justin Peralta
        you have the plug or weld that hole on the o2 housing and then put 2 o2 bungs on the bottom of the exhaust, one for the stock o2 sensor and 1 for the wideband
        You have been defeated by a car with child locks, how embarassing...
        "I noticed my f22 felt "healthier" until it blew up." <Myk>
