hello evryone, i am a new member and i got a question and i hope you could help me. for some time i was thinking (or hoping) on doing the h22 swap to my accord untill i herd about the jdm f22b. it is more affordable and it has a decent hp. is it a good idea? how dificult is the instalation?
f22b jdm
well the f22b has about 160hp and the h22 has about 190hp(im not that shure about the h22) but since i have an f22b i can vouge for it... and the swap is easy for the f22b its just a streight drop in... wire harness is the same and everything bolts right on nicely...Upgrade your mind before you upgrade your car
"So. Cal OUTLAWZ"
Originally posted by dohcb7well the f22b has about 160hp and the h22 has about 190hp(im not that shure about the h22) but since i have an f22b i can vouge for it... and the swap is easy for the f22b its just a streight drop in... wire harness is the same and everything bolts right on nicely...
were can i find a place that sells the f22b and how much can i espect to pay for it with the tranny?"YO NO QUIERO SU PINCHE CHULETA, QUIERO SU PINCHE VIDA!!"
welll ur talking about the f22b non vtec 92-96 jdm prelude si motor.
and its rated at 160 hp at 6000rpm and 148 lbs of torque at 5000rpm.
so it only about 30 hp more than stock and 40 hp lower than the h22.
i've got the honda tunning may 2005 where they do the swap and show
you how.
and they also turbo'ed it. from a cb7 with a f22a4 to f22b jdm turbo
all took 8hrs
All F and H series transmissions are interchangeable. I would also suggest you upgrade to an Exedy stage 1 clutch while it's all out, so you have a stiffer tranny. I've looked at the F22B DOHC a couple times now, and it's basically and H23 with a bit less HP and Torque.someone correct me if I'm wrong. If your going turbo, then this is your engine. It holds the pressure better. Good Luck with your swap.
Originally posted by kmart64hmm..klinda off topic, but can you swap the f22b head, and use a 260 or 272 delta camshafT??? I think that would work well with this swap am I correct?
You could have Delta make custom regrinds for you, but you can't use the cam from an F22A because they are SOHC and the F22B is DOHC.
The head is pretty much identical to the H23 head, so you can probably use some of the aftermarket cams from companies like Crane.
Originally posted by Spartan1987All F and H series transmissions are interchangeable. I would also suggest you upgrade to an Exedy stage 1 clutch while it's all out, so you have a stiffer tranny. I've looked at the F22B DOHC a couple times now, and it's basically and H23 with a bit less HP and Torque.someone correct me if I'm wrong. If your going turbo, then this is your engine. It holds the pressure better. Good Luck with your swap.
once and for all, the h23 is 160hp and 156tq. f22b is 160hp 148tq. f22b has 9.2: compression. the h23 has 9.8:1 and it has .1 more liters, that where it gets its torque from. the jdm f22b head is the same as the h23, BASICALLY. you can use delta h23 regrinds in the f22b head, h23 valves and suchShift_BOOST
BOOM!
Redline is when your tach is pegged to the end. Those red marks on the tachometer mean nothing. I take my h22a up to 10k daily lol.
