Check Engine Light
    Check Engine Light
    I Have A Problem With My Cb7... I Just Swaped My F22a To An F22b And It Runs And Drives Good But When I Go On The Freeway And Hit Over 70 Miles Per Hour The Check Engine Light Turns On... The Car Also Has This Weird Gasoline Smell, But Its Had It Since I Bought The Car And I Dont Know If All This Is Something I Should Be Worried About Or If Its Normal
    Upgrade your mind before you upgrade your car
    "So. Cal OUTLAWZ "
    1. Jump the code
    2. What ECU are you using?
      Originally posted by NAiL05
      1. Jump the code
      the stock f22a ecu
      "So. Cal OUTLAWZ "
        Well if your using the stock f22a ecu that could be a problem. And if i remember right all the f22b motors are vtec. So your not even engaging into vtec when you get into high rev. But thats the only solution i got. Change ecu's.
          yeah but not all f22b motors are vtech... this is a none vtech f22b dohc
          "So. Cal OUTLAWZ "
            So do you have the f22 dohc from the prelude?
              If your running f22b dohc run the p39 if not chipped p06 if you have a b1 run the POA or a chipped p28. To me I think he has the f22b non vtec since he says over 70 the check engine comes on. if he had a b1 and used his stock f22a ECU he would have already throw code 20/21. Anyways the f22a ECU is a good temporary solution for the f22b dohc but I would eventually swap it out for a p39/chipped p06 to use the full potential of the motor. But jump the CEL first and see what code you are throwing first.
                In a way thats kinda what i did but for the knock sensor. I used the my stock pt3 untill i wired in my knock sensor then switched to my p14
                  Well the p14 requires one anyway so yea that is kinda a have to kinda deal.
                    Yep. Got one for sale if you want it. lol sorry for kinda jacking the thread
                      its no problem... oh and i got the f22b dohc none vtech... and how much are u selling ur ecu???
                      "So. Cal OUTLAWZ "
                        HEY dohcb7 if you need help with your ride i can help you out
                        ________
                        Black dick
                        CLICK ON SIG FOR MEMBERS RIDE
                        "2SIIC"
                        Authentic Jerseys for sale
                          Well i could probably let it go for 35 or 40. Give me your zip code and i will give you a price including shipping. If you want you can just pm me, instead of messing with your thread. Later -Jason-
                            yeah ill do that...
                            "So. Cal OUTLAWZ "
