Changing manual trans. fluid
    Where are the drain plug and filler located? Any special tricks I need to know? I searched the forum, but had no luck finding this stuff. Thanks in advance.
    search again theres tons of shit i even posted stuff way back when i was noob
      I used an old beer bong for the refill, it is a pretty easy fluid to change though, loosen bottom plug, drain, close bottom plug, open top plug, fill let excess ( if any) leak out top hole, close top hole.
        ^^^exactly what he said.
        LMFAO! a beer bong, that is genuis! The perfect way to fill tranny fluid!
        1990 Accord Lx F22a1(Daily) SOLD - will be missed
        1990 Prelude Si B21a1 (Fun car!)
          ^^^ am with stupid
          nice lol
          Not my fault my dick only fits magnums.
          Why drink and drive when you can smoke and FLY?
            I haven't been able to find much regarding a manual transmission fluid change either. Tried various words in the search function.. I get either nothing or 500 posts.. Hmmmm Grrrr...
            A DIY would be excellent if anybody is up for it???
            1990 Accord EX 4dr Purchased New 8/21/90
            1999 Explorer XLT V8
            2001 Mustang Bullitt #2818
              sorry man, but i dont think a DIY is necessary for it bro.
              I <3 G60.
                i cant believe u wrecked a good beer bong but ow well, remove the top one first and then the bottom so it drains faster and just to let u know, if its gear lube dont smell it cuz it smells really really bad
                  It is good to change the tranny fluid (what frquency ?) If I do it, will my tranny get better shift or it wont change anything !
                    Like they said...use some of that Honda MTF, I hear it is the best for the manual tranny. The Haynes says you can use engine oil, like 10w20 I can't remember exactly. I filled mine with engine oil and it shifted like butter.
                      i filled mine with 10w-30 motor oil. Shifts fine for me. But whatever you prefer
                        Just use regular engine oil, there's no need to buy expensive Honda MTF. 10w30 is the proper oil, IIRC.
                        - Ghosty
                        WTB: MAP sensor (2+bar), IAT sensor, ECU & dizzy harness plugs... PM me!
                        FS: coupe window rain guards, f22a6 intake & ex mani, cams, PT6 ECU, valve cover, dizzy caps, OEM fogs... PM me!
                          It was the correct lubricant at the time the manual was printed.
                          Regular production motor oil has changed enough since 1992 to consider using what Honda currently recommends.
                          2003 Maxima SE Titanium Edition
                          1993 Suzuki GSX1100F 136bhp
                            the drain plug is a bolt that a 3/8 rachet fits on (with no sized socket just the rachet itself), it looks like a bolt with a square. it has a crush washer, make sure you change it. the fill bolt is about 6-8 inches above the drain bolt, more closer to the top of the tranny. it is a 17mm, it too has a crush washer, it wouldn't hurt to replace that one too.
                            to change the fluid, undo the drain bolt and the filler bolt and let the fluid drain out. put the drain bolt back in. insert a funnel with a rubber hose on it into the hole and fill until fluid runs out of the fill hole (approx 2 quarts).
                            then install the the filler bolt. make sure you don't over tighen the bolts, remember the tranny case is aluminum and is softer then the steel bolt you are putting in. make it snug, start it up and check for leaks. later.
                            Avoiding dirt at all costs
                              Thanks for the clear and concise explanation, it was very simple.
