I searched for the scattered info but came up frustrated.I wanna swap a F22b1 into my 90 Ex coupe and am tryin to figure out what I need to change to accomedate that motor.Only mods are intake and axleback exhaust.Besides what i need to change, I was also wondering what the best ECU for my situation would be.I plan on possibly goin turbo or heavy mods in the future,but whats good for now?.thx.later
F22b1 swap
haha, i know, sohc vtec if im correct....you will need to change out the exhaust header, the f22a will not fit it because of the different hole, and bolt pattern on the f22b, other than that, its a pretty much bolt in, and ecu u will wanna run 94-95 sohc vtec accord ecu, i believe 96-97 are obd2 and thus the plugs are different!!! unless u runs somthing that is chiped!
http://www.cb7tuner.com/vbb/showthre...22b1+swap+info
go there. You can run a chipped p28 or a POA which is what comes with it.
man its a easy swap me and a friend did one in his cb7 took 2 days third day it was driveing i think we used the stock ecu from a 94-96 accord i think and it ran great his 4d sedan went and ran with a gsr on the highway his 91 is sweet next to come is boost as for mine stock soon to be f22b and boost so do the swaphttp://www.2kracing.com/index.php/cPath/4_60?osCsid=9dfebfe0d4f332b5c7b3498b65c09864
http://www.naganojapanese.com/jdm_f22b.htm
haha, thats all cool, but the swap should be just like taking the old one out and puttin it back in, with the exception of the header, and ecus, you will need to wire up vtec.....hehe..... other than that, it should be a nice joy ride......in the processe of dohc head swap on my f22a1.....should be fun, but hard to find the dohc head, either f22b dohc, or h23 dohc!
Originally posted by F22Accord91man its a easy swap me and a friend did one in his cb7 took 2 days third day it was driveing i think we used the stock ecu from a 94-96 accord i think and it ran great his 4d sedan went and ran with a gsr on the highway his 91 is sweet next to come is boost as for mine stock soon to be f22b and boost so do the swaphttp://www.2kracing.com/index.php/cPath/4_60?osCsid=9dfebfe0d4f332b5c7b3498b65c09864
Get a p28 with a b1 basemap. That should set you straight. There are plenty of people on ehre that can help you with that man gl with it.
