What up, my accord 91 ex. Has the check engine light on. They told me that its because the Oxygen Sensor.They tested it out, they jumped the cable w/Blue plug under the pass side. So i found a Sensor at AutoZone (64.00) (BOSCH). So i wanted to know can i remove the o2 sensor , and Install the new one. LIKE IS IT THAT EASY, OR No. I know the sensor is on the drivers side, under the hood, rear area of the engine, next to exhaust Manifold. CAN THIS BE DONE THAT EASY. Also like how do i know for sure this will take the engine light off. But regardless, i'm gonna change it , because it needs to be changed , gas saver, better performance for my motor.
P.s. Just incase i have to go to HONDA, To see if they tell me whats the reason for the check engine light. Bout how much do you think they'll charge me. THANKS
