well next time you going to fix ur internals check your bearings compare them #1 bearing with the number #5 bearing and oil pump. just an fyi since your underdriving your car and no im not trying to start up anything again. but yah look at my tag i made it today LOL
Underdrive Pulley
Originally posted by trahwell next time you going to fix ur internals check your bearings compare them #1 bearing with the number #5 bearing and oil pump. just an fyi since your underdriving your car and no im not trying to start up anything again. but yah look at my tag i made it today LOL
Originally posted by deevergoteI still can't possibly see how the pulley could affect the oil pump...
Bearings, yes. I can see that. But only if the pulley isn't properly balanced. Which supports my reason for only buying the quality ones.
Originally posted by HondaB18Is that a pic of your Civic's interior? Looks like its from a 3rd generation Integra and not from a 4th generation.
One reason I can think of would be the excessive vibration which may affect the bearings and other parts which many be connected to the crankshaft (like the oil pump). Another reason I can think of would be the oil pump material and its build, the weak metal would grind against the housing causing them to fail. Third would or could be due to the oil pump's backing plate and how it flexes. Because it would happen over a period of time, there hasn't been any real answer to that question.either kill it or drift it...
2002 Toyota Tundra V8
Originally posted by trahI never stated that my interior is a 4th gen integra. its a 3rd gen. Only things that don't work is the hzard lights, rear defroster and dimmer. everything else works just need bondo and new body kit and im set to roam the streets with it.Originally posted by trahi was driving in my 93 civic (DC5 interior conversion) (UR undercrank pulley, AEM pulleys, d15 block d16 vtec head, d16 tranny, injen intake, dc header, greedy 2.5 exhaust)
No matter, not a real big deal. I'm just a big Integra nut.
