Buying a ground kit
    Originally posted by d112crzy
    not really. i did mine just a few days ago.
    Yes, and I installed my headunit 3 or 4 weeks ago and must have screwed up every crimp like 3 times, I don't like crimping.
    Back on topic though, which one should I get, whats the difference, or should I not get any at all.
    I'd eat a baby for free. I'm hungry, dammit!
      grounding kits add power? what exactly do they do....sorry to thread jack..
        Originally posted by Fr0z3N
        Sorry I'm not trying to ghetto rig my grounds.
        hah its the same concept. duh.
        Retro!
        Hater
          Can some1 give me some advise on how to diy? Like the type of wires i need, etc. U can pm me the details.
          Thanks
          Sorry to threadjack.
          Vouches: Bruno8747, 1badwag, Excalibur02, Bliz07, Slick, Gloryaccordy, H23CB7.
            Just go to a car audio store, buy 4 gauge wire, buy crimpers, buy the little round things, cut them to length with a wire cutter, crimp the thing on the end, bolt it down. Repeat as nessacery.
              Thanks
                How about the crimping part?
                Do I need a special tool?
                I went and I googled, some tools cost $40 or so?
                hahahahah
                  For the larger wires I like to use a bench mounted vice. They make special kits for specific crimps, but you can get by with just the vice for power wire.
                  Just insert stripped wire in the crimp terminal and compress on one side of the "split" to push it down past the other side of th split. Then compress the sides, pushing one side under the other. Then rotate 90 degrees again and compress. If you wan to get anal, you can then solder the crimp, but you'll probably need a torch....lol. Make sure you get all the resin you can off afterward, wipe down, and heat shrink.
                    do people have pictures of their custom ground? if so I'd like to buy some to replace mines. i think the ebay ones are very clunky. my friend has his and it looks like a mess, granted he did not tie it down and etc.
                    hahahahah
