have you beaten your new clutch.. if so you didnt let it break in!!
New Clutch is slipping!!??
Break in time will slip when it's hot. But if it's been a few hundreds miles you should be past that point.
Next, adjust the pedal, if that doesn't fix it, verify that the slave cylinder is not applying pressure.
At that point, you have to think about things like the throw out bearing, or that maybe the pressure plate is faulty.90 4Dr.CB7, 416,XXX KMS and still running like a champ!
