what controls the fuel pump.
    ok as i understand it goes from the ecu-->main relay-->fuel pump... is this correct or am i missing other components that control the fuel pump...what about the fuel sending unit, what purpose does that serve? i need to know why my fuel pump is acting funny.
    thanks in advance.
    the fuel sending unit tells the needle how much gas there is.
    what do you mean your fuel pump is acting funny?
    the fuel pump is one of those parts that when it goes bad, it never starts working again.
    if it is comming on, then off, you should consider a wiring problem like corroded or lose grounds, or main relay.
    the main realy is something that works sometimes and not others and is usually weather related (when it's hot). a cheap, easy fix would be to drip new sodier on the sodier joints of the relay. later.
    Avoiding dirt at all costs
