pipe size
    pipe size
    When i put my H23 manifold on, do i have to use a prelude intake? Because i have a short ram one in now, do i have to buy a H23 short ram to fit the throttle body?
    1991 Cb7 Coupe 5 Speed--SOLD
    2002 Nissan Sentra SE-R Spec V-- SOLD
    1994 Acura Legend GS
    Car Pics
    That should fit okay, but a bigger size is always better.
      (^Um I know this is the noob section but common...)
      Bigger is not always better despite what your last gf told you before she dumped you! I know we've all heard the example of a water hose flowing faster when the same amount of water is forced through a smaller diameter hose...so I wont bore you with that.
      H23 TB's are bigger than F22x's; by 3mm I believe. 63mm vs 60mm respectively.
      A shortram is a decent choice if you want to avoid hydrolock (your engine sucking in water, which we remember from middle school science class is not compressible) there by destroying your engine. However, there are COUNTLESS threads on this very forum explaining how a stock airbox with some slight changes, actually produces the most hp.
      So, sit back, think to yourself "why do I want a SR intake? What is the POINT of an intake, after all?" then hit that search button up for some killer info.
      Hope this helped. Beginners.
      - Zipcreature
      Awesome!
      CB7. F22A. 5spd. CB7. Exedy. Chromoly. AEM. DCSports. Apexi. Progress Group. AGX. Suspension Techniques. Viberant. Goodridge. Facebook
