4 Wheel disk brakes
    4 Wheel disk brakes
    I have front disk and rear drum what can i do to get disk in the rear is thare a car i can rob them from and bolt right up?
    i would rather be dead and cool then alive and uncool.
    here's a DIY rear disc conversion that was posted:
    http://www.cb7tuner.com/vbb/showthread.php?t=10495
      92-93 EX brakes work. EX wagon brakes all around are even better. You can also get the rear arms and sway bar from the EX, which is cool
        You can even convert to five lug up front and back and have discs. Might be pricier BUT you'll have a bigger rim selection in the long run. Check out the DIY section for all of this info.
        ...adjust accordingly
