Ok, my car has some Accel wires on it, they were on there when I got it. Well I went to paint the valve cover today only to discover that no amount of pulling will free the plug wires from the valve cover. Is this car just wierd? Does you have to do something special to remove them? I tried pulling with all of my might and none of the 4 will budge.
Spark plug wires stuck??
I read somewhere that marijuana effects the memory. For some reason I can't seem remember where I read that. -- max sideburn(aka torqstr)
"Those who would sacrifice liberty for security deserve neither." - Benjamin Franklin
CB7: The Movie TEASER VIDEO
Tags: None
no, I've had that happen before. What I'm saying is that the wires won't even break. They're really tough and no amount of pulling on them will cause them to break or come loose. It's really wierd.I read somewhere that marijuana effects the memory. For some reason I can't seem remember where I read that. -- max sideburn(aka torqstr)
The heat from the sparking makes the tip of wires and plugs expand then they contract when cooled, it they were on too tight i think they can get welded together if they get hot enough, this is just speculation(sp).1993 Accord LX - Sold
93 BMW 525it - SOLD
92 Accord EX Sedan - SOLD
2000 Accord Coupe - Traded-In
2003 Accord V6 6spd Coupe - Sold
2001 Honda Civic Ex - SOLD
2013 Chevy Traverse LTZ - Kid hauler
2003 Acura Tl 3.2 - Daily Commuter
My spark plug wires were the same when I got my Accord. They ripped in half when I finally resorted to using a pair of channel locks to grip them to pull them out. They were all swollen and fused - I'm guessing because of heat. I'd keep pulling, there's no trick to these wires. Just have a new set on hand.
Can you get them to move in any direction? Side to side? Back and forth? When I went to replace mine they were stuck a little but I moved them side to side a few times and they then popped right out. And like the previous post said, "the heating up and then cooling down tightened the gap between the wires and the plugs." I could see on the wires where this had happened. Hopefully this will help. Later
