Hey, I could really use some help:
I have a 91 Honda Accord LX with 120k. It is fuel injected, manual, 4dr.
For about 6 weeks it has had a problem where it will sometimes not start. It will crank just fine. I was told by some idiot mechanic that "he'd seen it 100 times and a new starter would do the trick." So I changed the starter and it still does it.
It will ALWAYS pop-start. Also, if you wait 20 minutes to an hour, it will start. Sometimes it goes days without doing it. Sometimes it does it twice a day. Does it when the engine is warm. Does it when it's cold. Ruins my life.
So the obvious suspect is spark: I unplugged the wire at the distributor end and you can see the spark jump, so that seems to be ok.
I am pretty sure I hear the "click" after the CEL goes off.
I am just about to go buy a new main relay. But my question is would the car still pop start if the main relay was bad? I mean how does it make a difference between when the starter is turning the engine and when you're push starting?
ANY help you can spare would be MUCH appreciated. I'm dying here.
