Correct Tire Psi
    Correct Tire Psi
    I just ordered some 205/40/17 Falken Ziex 512 tires. What sould the correct tire psi be around. Thanks
    28-32 Psi
    Originally posted by DoctorCipher
    ...the beginner forum was created to provide a place for all the stupid ass questions to pile up and fester, kind of like huge globs of mayonnaise left in the sun for weeks at a time.
      An accurate answer would be to tell you to read the sidewall of the tire. It is molded into the information on the sidewall. In terms of maximum pressure for a full load in the car. So if you drive with yourself and no passengers most all the time, you can reduce the pressure from the maximum. Some say 10 percent reduction, but that is up to you. You could try out a few pressures from maximum downward and see what you like. But the main thing is that each tire tells you its own max pressure.
        theyre usually 44psi max, i run mine at 35
        You have been defeated by a car with child locks, how embarassing...
        "I noticed my f22 felt "healthier" until it blew up." <Myk>
          i always run mine at 35 good even wear
