The end links on my front sway bar is bad they have been for a while Im finaly going to fix them and I found the frame bushings for them on ebay there from energy suspension and there polyurethane. My question is the ad says there for 25mm sway bar I was wondering If anyone knew what mm our sway bars are I no longer have a set of calipers to measure them and im stumped also on polyurethane isnt it best to put some grease on them so they wont squeek. THANKS
sway bar ??
If they have the bushings for our cars listed at that size, then I would assume that is the stock bar size.
When I installed a rear sway bar, the kit came with some grease if I am not mistaken. I would guess that some moly based grease would work well. Im not sure if there is special grease for polyurethane bushings.
