starting
    starting
    i changed the alternator yesterday and car runs fine now .. but have a problem with a starting issue.. car starts sometimes and doesnt. have to sit there for like 10 minutes before it starts but if you turn it off it takes forever tto crank again.. but the battery and alterntor are good
    ~howz da twig n giggleberries~
    Maybe the starters bad check that
    I'd eat a baby for free. I'm hungry, dammit!
      bang the starter with a rubber mallet or sumthin to c if it starts rite away. if it does then u no ur starter is gone
      Hold On Not Done Accelerating
      Had One Never Did Again
        Starter or Main Relay. Does it happen in hot weather only or all the time?
          ^^^ ditto, if its the main relay i got one for you....if its the starter and ur auto, i got one for you too, lol
          Formerly 91AccordExR33
          11.68 @ 127mph
          417whp/375wtq
          Sold: 8/2016
            Check the main relay:
            http://techauto.te.funpic.org/mainrelay.php
              If the link I posted isn't working(it wasn't for me this morning) go here:
              http://techauto.tripod.com/
                If the engine turns over fine but doesn't start then I would say it's the main relay. If the engine has trouble turning over and doesn't start it could be your starter.
                Member's Ride Thread <------
                http://www.cb7tuner.com/vbb/showthread.php?t=80863
                Thats what it issss...
                  same problem...
                  had the same problem a while back and it turned out to be the igniton switch wiring harness (forgot the actual name for it) Ws weird would be an off and on start. No mechanics could figure it out and then this guy in Santa Cruz, CA took 10 min with it, figured it out and had the problem fixed within 20 minutes. So check that bro, not really sure how but that was my issue. Good luck!
                  MadLab Racing
                  Southern Maryland
