Flashing Oil Light
    Flashing Oil Light
    Does the flashing oil light only mean that oil pressure dropped below a certain level or does it mean something else to. Sometimes for some reason it will just come on and start flashing. I turn the car off and then back on and it is fine again. What could be going wrong on my car. I would like to fix the problem before it gets even bigger. I know a flashing light can never be good.
    Girls are like yellow lights, do i go for it or do i stop?
    is your oil level ok? check engine light? how does the car run
    My Members Ride Page
      when does it flash? accelerating, turning?
        Twice will turning pretty sharp, and the other time I was turning normally. My car runs like a champ other then this small problem. I just had my 120000 tune up done if that makes any difference.
          prolly gravity working there since you said it's only during turns.
          just check your oil level again to make sure it's ok.
            any weird knocking noises. does your car want to die when you come to a stop. hows your oil level. let me know. mine did that to and then 3 days later i blew my engine.
              If your level is okay and you don't have any big leaks, it could just be your sensor. Does it keep on blinking while you drive? You said after you shut off your engine it goes away...
              My car did that a while back... I thought i was burning oil, but the oil was always up by the second mark on the dipstick. It was just a bad sensor on my car.
                mine did that once but it was beause i had a little to much oil in it but if your oil level is ok then it could be a faulty sensor
                ________
                NEXIUM PREGNANCY
                CLICK ON SIG FOR MEMBERS RIDE
                "2SIIC"
                Authentic Jerseys for sale
                http://www.cb7tuner.com/vbb/showthread.php?t=188314
                  Mine used to flash when idling or during sharp turns. Turned out to be the sensor. Check your oil level first though, since that's, you know, free
                    Im gonna say check your screen under your oil pan....if they did any kind of cleaning all that shit went to the bottom of your oil pan and is now cramed into your oil pump screen. check that out and spray it with some carb cleaner
                    happend to me too and blew my engine a week later (screen was full of shit)
