Hi guys, been a while...
Need to change the tranny fluid in my Ex. Having said that, almost everybody up here has said at one time or another that you should use Honda ATF. I dont have a problem with that as I want my CB7 to go as long as it can, but I've got 8 qts of Amzoil ATF sitting in my garage leftover from a change out in my Dakota (using Amzoil oil in both engines right now). Would you recommend using this or sticking with Honda ATF? Amzoil says it'll work in anything and next to Honda's, Dodges are very finicky when it comes to trannies.
Also, is there a way that I can drain the torque converter without taking the tranny apart or just use the flush method.
Thanks
Thanks
