I swapped an H23 into my 92 accord and did not hook up my knock sensor. If your wondering why its because i didn't have the pin to wire into the ecu. I drive the car daily and was wondering what harm it will do if i leave it unhooked? Will i be loosing power or possibly damage some internal parts? Any info will be very very helpful. Thanks
Knock sensor????
My buddy replaced his yesterday in an H22, it's something you need to have hooked up. Basically, it senses detonation and other timing related issues via means of a ultra-sensative ceramic mic..... and adjusts the timing accordingly. After it was changed, the car ran noticably better. That, and the EGR was crammed full of carbon.
They are over $100 new from Honda though.....1992 Accord LX - SOLD
original ecu
my undersatnding is yes it will, but at the same time your car will run like it should until you have the time to get that knock sensor wire in correctly. For a DD you should just chill a couple of days till its fixed Then go faster than 100. So IMO that would be what I would do!
First of all if your KS is not hooked up and your car isnt runnin properly DO NOT GO PAST 100...I dont even know why you would need to go that fast on a daily basis. The KS retards timing if it senses anything like detonation and all that in the motor. SO it will slightly hinder performance. And no the KS did not only just come in VTEC motors. They also came in non vtec motors.
I have only taken it up past 100 once, for sure that i know about. you always have to test something out when you do a swap or some performance mods. but i am actually going to the junkyard today to get some other things and im driving my moms car there so when i get back i can hook up the KS withoput burning the shit out of myself. Thanks for all the info.
