choking
    choking
    So i have another problem.... my car has an H22 and its running like shit after the tuneup. it has new cap,rotor,plugs,wires, everything. its getting too much fuel and the engine is running like its choking. its not throwing any CELs, ive thought of everything. the ECU has been chipped with chrome, could it be the basemap on the ecu?? could it be the fuel injectors or the fuel rail?? if i swapped the ecu with a different one would it run better?? any help would be great, thanks
    new ride
    07 cobalt ss/sc
    i would suggest looking into the firing order, correct plug gap, make sure rotor is on correctly also check timing, and lastly try that ecu, which i doubt will be your problem, good luck
    Members Ride
      Thanks for the info, ill check everything out.
      Does anyone know if i can get a packet of all the information for the H22A, kinda like you can from all-data or mitchell on demand. or maybe a book??
      new ride
      07 cobalt ss/sc
        you can buy an prelude helms book at autozone or something, for the h22 motor,
        Members Ride
