Heater, Overheating ???
    ok i know when your fans arent working and your driving when you turn your heater on its suppose to cool the engine down and help things out. well i had a problem before that my fans was not going on at all when i was driving only after i turn off the car. but the thing was. when i turned the heater on thats when the guage would go up to about 3/4 up. so what would that say? maybe the heater core glugged? cuz that wouldnt make sense.. anyone at all could figure that out ?
    do you have any water leaking on the passenger side floorboard? That would indicate a bad heater core. Also for now you might want to just run your fans off of a toggle switch until you can troubleshoot this problem and get it going.
    I read somewhere that marijuana effects the memory. For some reason I can't seem remember where I read that. -- max sideburn(aka torqstr)
    "Those who would sacrifice liberty for security deserve neither." - Benjamin Franklin
    CB7: The Movie TEASER VIDEO
      no i dont have any water at all. but that what was my problem before. i couldnt get my fans to turn on while i was driving for a while. til i swtiched both sensors and the timer fan.but that wasnt the problem. i guess when i did a flush i had some nasty ruber type stuff in my system. maybe old oil build up. and the flush pushed it to a point that it maybe were the sensor couldnt read the temp.
      i fixed this problem when i blow a air system thru my engine and hoses to see if maybe there was anything blocked and there wasnt. when i put everything back together all that stuff pushed into the radiator. so thats how i got my fans to finally work. but my problem now is.
      after turning off the car the fans still do the same thing that did when it first got messed up. staying on for about (3 to 12 minutes) after i turn the car off. also noticed after i turn off the car and the fans come on. and if i was to put the key back in and turn it so were all the lights on the dash come on. then the fans will shut off. (actually only one fan comes on after i turn the car off. the one on the passanger side,both come on when the car is runing). then when i turn the car back off then come back on. i mean something isnt right. i know on some cars there suppose to come on after u turn the car off but not my car. i had this car for a while and after i did the flush thats when i got into all these problems. can anyone figure this out?
