doesn't shift
    doesn't shift
    i just got new spark wires, plugs, caps, and rotors for my car about 2 weeks ago and i've noticed this really big problem. i've got an automatic and every time i floor it, it shifts from 1st to 2nd fine, but when i get up to about 60mph revving at 5500, when my car always used to shift, it doesn't anymore, the stupid thing just stays at a constant high rpm level. it's jacked up and this only happened after i got it back from the mechanic. this sounds like it could be a big problem, but i dunno what's causing it. my tranny always shifts normally when i'm not flooring it, just when i want to race another accord, this thing won't shift.
    don't quote me but it might be your shift solenoid
    Rocesride Member Page
      my tranny does the same thing I have to let go of the accelerator alittle bit for it to shift then I press on the gas. Do you neutral drop it?
        Shift solenoid if it aint goin up any higher than second gear.
          by neutral drop do you mean rev and then throw it into drive? yeah sometimes. i just thought it was weird because this problem only started after my mechanic messed with my car.
            yea thats a neutral drop Its very bad for a trannsmisson that could have contributed to your problem
              yeah i know it is considering honda trannys aren't so great anyways. is there something the mechanic could've done to make it worse. doesnt seem like plugs and wires would have anything to do with a shifting issue.
                neutral drop= big no no. but sounds like it could be the shift solenoid...u can get it tested at a tranny shop or just try and find on at a junkyard like i did. Brand new your lookin at $150-$200.
                  Hmmm have you checked your tranny fluid?
                    What was your mechanic working on?
                      ATF would be a good start
                        nope. never. whats a good way to check it. isn't it that yellow tipped stick below and to the left of my engine?
                          yes Its that yellow tip stick
                            make sure your on level ground when checking it...smell it also. see if it smells burt or has a dark tint
                              all they did was change the spark wires, caps and rotors, and new plugs. they also did a sort of fuel injector cleaning
