my sunroof dont work, were is fuse located?? also what else should i be looking for that maybe problem??
SUNRUF wont open
Originally posted by amd3dnow3so there is a way to operate this thing manually, how i try to push the roof up with no luck, how do i unlock it or make it move by hand??
Originally posted by tunermanalright first you need to take off the whole sunroof then get a 14mm socket connect it to the electric engine and then when you crank the motor the glass will start coming foward, but it is real hard to put it back on so you should have atleast 2 other people with you. it's funny cause i'm installing a sunroof on a cb right now.
mang that sucks i thought you can just work it by hand without removing it, i want my sunroof working i just got it so not sure what problem is, again any one sure were fuse is?
Not my fault my dick only fits magnums.
Why drink and drive when you can smoke and FLY?
