Amp ground?
    Amp ground?
    Where can I ground the amp to, nothing in my rear trunk is working, under the rug that is, any place that promises to work?
    2 kicker comp's 12 inch and a 700 watt rms amp
    Meh, not feeling the honda game anymore.
    MY CAR IS SOLD!!!
    Any steel on a car will give you ground as long as the paint is out of the way. The shortest distance from the AMP to ground is best, and same gauge wire as positive wire. You may want to take a quick look at the ground wire on the battery. I had one go bad down by the transmission, it corroded away.
    It really is a labor of love making a neglected CB7 with "normal wear and tear" into something worth being proud of.
      ground it under the rug where the seat ends
      TOPEND PERFORMANCE
      R.I.P SPIRO
        there should be a few places where the bottom part of the seats meet the back rest.. try to keep give it a lil distance from the fuel pump.
        My Accord
        www.d1imports.com
          I mounted mine under my seat and grounded to the seat bracket.
