Susp. installation
    post up pics. I can't help you without a pic of what you are talking about. And wrench that nut ALL THE WAY DOWN!!!! It doesn't need to go down just a "little better." It needs to go all the way down. If you can't get it down, compress the spring more until you can.
    "This is a jaded bunch. To gain notice, you have to challenge conventional wisdom, test assumptions, and ignore the naysayers."
    FS Part out thread koni/skunk2 suspension, jdm pole, HID retrofit, Tanabe exhaust
      yes
        Well, I finally figured it out. I was having a problem threading the nut because 1.) it was already down as far as it could go 2.) i hadn't used PB Blaster 3.) I needed to spread the spring compressors out more on the springs 4.) the shocks were used and the threads were a little stripped
        So when i went and did the other side it was easy as pie, now that I knew what to do.
        So thanks to everyone that gave advice and suggestions while I was freaking out. It was definetly worth it.
          good luck with your suspension pm me pics of it when done wouldnt mind seeing it..
          1991 Honda Accord
          www.animatedimages.org
            I'll probably have pics two days from now, I still need to tackle the rear tomorrow.
