so ive had the h22 for about 1k miles and dont really beat on it to much lately little bit more, I check the fluids and everything make sure there good. But lately when I go to start it, after it sits for 4-5 hours it doesnt start on the first turn anymore, it turns over 5-6 times then it comes to life. My guess is that after the hard drive it gets warmed up and the heat causes the fuel to be pushed out (towards the gas tank) of the fuel rail/line. Something like this would happen to my boat if u stopped it cause the cooling system would stop and the block would continue to heat up causeing the fuel to evaporate or get pushed out idk. Just posting cause its my baby and i want to keep it in tip top shape
h22 starting problem maybe?
Originally posted by deevergote..It's not cheap to build a fast CB7, especially NA. However, if you're willing to put the money into the car, it's well worth it in the end. There ARE faster cars out there, but some people, like me, want THIS particular car to be fast!...
Bought from:93a-lude, bruno8747, soysauce
1993 H22A cb7 <3 miss you
04 WRX stg 2 sedan
Current - 02 WRX stg 2 wagonTags: None
Check your main relay. That would be a first check I would do since our cars the main relay seems to give people hell at times and are very prone to not work in hotter weather.
Do you mean the 5th or 6th crank.. or rotation of the engine?
Mine will crank.. and then will start up slow, and kinda sputter for a second or two, then jump to life. If I crank it quick, then crank a second time it'll start up quick. I think it has to do with my tuning although it did go away for a little while, so i dunno.
