Problem during Lowered cb7
    Hey.Norwegian here.
    I just got lowered my euro accord with koni shocks and 40mm H&R springs and the results started pretty good in the back but in the front it lowered only a few mm!
    anybody had the same problem?
    Ehm... sorry if my english is bad, i do my best
    Euro Accord 2.2i -93 (With Kw Coilovers )
    hmm... maybe the springs need to settle more?
      yeah, maybe. it looks horrible anyway, i can lay out a picture on this thread of it.
        Or maybe you installed the spring the wrong way..such as backs in the front and fronts in the back? How bad is it? It could also be because its not settled as mentioned.
          [QUOTE=NAiL05]Or maybe you installed the spring the wrong way..such as backs in the front and fronts in the back? How bad is it? It could also be because its not settled as mentioned.[/QUOTE
          after i installed the springs and shocks, the front has only droppet a few mm.
          And the rear turned out pretty nice. but the front looks like the original.
          But i can get some pics of it.
            Take some pics! If we could see what it looks like, we could offer you better advice. To me, it does not sound like the springs are waiting to settle. I mean, a few mm is crazy. Something must have gone wrong in the install. Post pics though!
            generic short-ram
            generic strut tower bar
            hid bulbs all around
            amber bumper + clear corners (soon to be amber)
              post pics would like to see what your talking about....did you cut the bump stop any? i have heard some say that this helps the lowering of it.
              1991 Honda Accord
              www.animatedimages.org
                it won,t uppload my pics! is there any other way besides that????
                  host them, then post the link with [img] [/img] wrapped around the link.
                  http://imageshack.us/ or www.photobucket.com
                  and it does sound like it needs to settle. mine took about 1-2 months to settle. it looked like stock when i has finished installing them.
                    here we go
                    okay,here are the pics of my ride,can,t belive its lowered 40mm! it looks like it,s stock!
                      hmm, yea. that definitely needs to settle.
                      but just to make sure, did you put the big, fatter springs in the rear and the skinnier ones in the front?
                        What koni shocks are you using? Koni yellows? Try setting them on the lowest perch, as koni yellows can a height adjusting perch.
                          Yes,i did put the big ones in the rear and the smaller ones in the front.
                          But if you turn the rear springs the other way,could that be the problem?
                          i am sure that the H&R writings on the spring, was the right way.
                            Yes it,s yellow konis. i think i can lower it 15mm on them,not sure.
                              spring rate for the front springs is generally higher, so it needs more time to settle. evne afte rmine settled, i still hated the level stance, i like the sport rake, so i put some spring spacers in there, and that evened it up some
