when i turn off my car the left fan of my radiator keeps going can anyody tell me what the problem is
Radiator fan wont shut off
Everything done on this baby is all by me, NOT one thing done by a shop or store
My myspace hit me up
Tags: None
Common problem. Might be your fan switch (Check your Haynes Manual), or the thermostat. The thermostat would just be telling the ecu that the car is still hot, leaving the fans on. Anyways, Chech those things.
And of course, I assume your coolent and water levels are correct. Home this helped.
- Zipcreature
I have the same problem, but mine never shuts off... you car should actualy if its hot enuf continue to run the fan several minutes after you shut it off... aslong as the fan actualy shuts of at some point.... Mine never shuts off. I just pull the Relay in the Fuse box under the hood and replace it. It shuts off when im driving and comes back on im guessing when it gets near temp but stays on when i turn the car off and leave it... im talking hours. Probly a thermostat or switch. or another case of 1/2 assed wiring the person who recontructed my car before i bought it did.I cant Slam further. The ground refuses to get any lower.
