I have an h22 engine but my bypass selonoid is not hooked up pls. tell me what this is for and what is does.
what is intake air bypass solenoid?
Originally posted by aznpnoyracerI have an h22 engine but my bypass selonoid is not hooked up pls. tell me what this is for and what is does.
if you mean idle air by pass selonoid its attached to the i.a.c. which is attached to the throttle body, am sure for f22 but should be same for h22 ME THINK.Last edited by amd3dnow3; 06-29-2006, 06:32 PM.
Not my fault my dick only fits magnums.
Why drink and drive when you can smoke and FLY?
Originally posted by whatever210i think what i does is it gives you more torque at lower rpms when the valve is closed but more hp at higher rpm when vavle is open. i think it opens a 4500 rpms.
As mentioned it suppose to give you low end and somewhat better gas mileage. Kicks in a few RPM before VTEC if I remember. If you just run it off vacuum it opens around 4000 ish.
Originally posted by NAiL05As mentioned it suppose to give you low end and somewhat better gas mileage. Kicks in a few RPM before VTEC if I remember. If you just run it off vacuum it opens around 4000 ish.
