it used to kick in after 4ooo rpm
Vtec Stop Kicking Any 1 Know Y ?
u getting any check engine lights? the solenoid is between the distributor and EGR valve, check to see if anythings been disconnected or shorted. also, your oil low?
dealer, junkyard, ebay, For Sale section here, hondaautomotiveparts.com...
could very well be the oil pressure switch (youve got enough oil right?), if it were the solenoid youd get a CEL.
you wouldnt need the whole assembly, just the sensor... JDM doesnt matter, itll be the same as the USDM one from the same motor. pull it out to compare it with other ones, there may be other cars that use the same one.
I think the GSR uses the same one if I remember because my motor was missing an oil pressure switch. If that was bad it would throw a code also and sometimes no. WHy is your VTEC set so low btw?
