Battery
    Battery
    I have a little problem... My battery connector (Pole) (excuse me i don't know what the good word in english :P ) are too large because i've clean them a lot... but now i can't tight them... the bolt i tighten but the *pole is not tight....
    What can i do ???
    You talkin about the battery tie down (piece of metal with two 10mm on each side) or the terminal (goes on the + and - side on battery) itself?
      The terminal, the thing that goes directelly on the + and - of the baterry :P
        You can replace the cable itself. They sell them at most of the auto parts stores. I had the same problem so I loosened the clamp put a nail inside the clamp, and retightened the clamp. The nail just takes up some extra space. It's a temp fix if you're in a bind. But make sure it doesn't stick up any higher than the battery terminal. If it does, it may touch the hood and ground out. BAD! VERY BAD!!!!
        Member's Ride Thread
        Will work for food, car parts, or three stripe apparel. And not necessarily in that order
          ok i'll do that and tomorrow i'm going to buy new one :P
          thx
