Need F20a Help Please!!!!!!!
    so i jus swapped an f20a in my 92 accord lx, my old tranny bolted right up to this, but my old axel(the one bolts on the engine to the tranny on the driver side) does no fit, which one would i be able to use, the car is running i jus need this so i could be done....any suggestions?????
    http://www.myspace.com/509cubanpapi
    92 cb w/jdm DOHC f20a
    11 sec all motor crx in the works
    you half shaft should bolt up to the block as normal...are you sure its in all the way>?
    Formerly 91AccordExR33
    11.68 @ 127mph
    417whp/375wtq
    Sold: 8/2016
      well i haven't really looked at it, i'm gonna take a look at it today after work, but i had it at a shop and the mechanic was the one that told me it didn't fit, i don't know i think he's an idiot though,so i brought it home yesterday..i was told it should fit though??
        it will fit...only reason i see it not working is if its not in all the way
        11.68 @ 127mph
        417whp/375wtq
        Sold: 8/2016
          is it going in all the way??? give more detail of problem, another thing make sure the spring clip is there and not damage, without it the cv wont stay in and just comes right out.
          Not my fault my dick only fits magnums.
          Why drink and drive when you can smoke and FLY?
            after i get this little problem fixed how would u compare this motor to the f22a1?? would kind of times do u think i will make in this motor compared to the 16.05 i made in the f22a1??
              depends man....its a lil more whp, just depends on ur driving. You'll notice how freely it revs and where your powerband moved....just get used to it, and try ur best...i see you in the high 15's if its a DOHC
              11.68 @ 127mph
              417whp/375wtq
              Sold: 8/2016
                would it be best to run an h23 ecu instead of my stock lx ecu??
                  oh and it did fit, idiot mechanic just messed up the thread on the block so i hade to rethread it, but engine feels alot smoother then my stock one thanks
                    kool, you punning the pt3 or the h23 ecu? h23 might be ok, but you'll throw a code for a knock sensor i think. I used a PT6 from a f22a6, or if you can find the infamous PT2, then run it
                    11.68 @ 127mph
                    417whp/375wtq
                    Sold: 8/2016
                      not sure what the numbers are to the ecu i'm running right now, all i know is that it's my stock lx ecu, what's the pt2 or pt6 off of?? would it matter, performance wise if the h23 ecu throws the knock sensor code??
                        wut's the pt3 off of??
                          where could i find the pt2?? and how good would the engine run with an h23 ecu??
