Changing timing belt.... what else should I replace?
    Okay so I'm changing the timing belt this weekend. What else should I change?
    1. 2 belts
    2. water pump
    3. 2 cam seals
    4. front main seal aka crank seal
    5. balance shaft seal
    6. timing belt tensioner
    7. balance belt tensioner
    The valve cover gasket and spark plug tubes are new btw
    What else? Please enlighten me!
    Change out all the seals in that area. Front main seal and cam seal. Also maybe do your valve cover gasket and tube seals.
    Also get the balance eal retainer from a honda shop. It will save your life down the road and it costs about 5 bucks.
    No longer working on the cb. To much time and money has been put into it. Check my for sale thread where the whole car will be parted out.
