since i dont have access to hole saw..what tools and ways do you guys use to enlarge the hole...i know theere are differ way to do this so...
Methods to cut intake whole bigger fo CAI
might not be the cleanest method, but enough banging and holes, possibly could work! i wouldnt do it that way....id use a dremel and some fiberglass reinforced cutting wheels and go at it, then take a grinding stone and smooth out the hole. then after that take some small vacuum hose, slit the hose in half down the middle ( not all the way through) and then line the hole with it. oh and u could use touch up paint and cover the RAW metal from the hole u cut before the vacuum tube....
just my thoughts.....
SeanF22a1-->F22A-->H22A-->auto-2-5spd-->K20 6spd-->F22C 6spd RWD-->4G63 6spd AWD-->K24 6spd????
Sold to: blackice, Myothercar, Rennat, Ilikebigbutts, HA91, DA92CB7, accord91lx, Cb7GHOST, Gemini, whiteaccord92,Warudakumi, jhondayaaj
Bought from: 93twodoorLX, Datmofo, g7kobayashi, accord_inspire, Accord SiR, Kurobei, UK-Accord, phreakish93, RENR, k-mart
Originally posted by 91accordexr33dremel ftw
I used vice grips too, but thats only cause i didn't have a dremel. If your worried about sparks just find a big piece of cardboard and blockoff the rest of the engine bay.Knowledge is power...in EVERY sense of the word
I went through a whole pack of cutting wheels and still didn't finish... so I used tin snips. The hole was fairly rough, but it worked. I covered it with electrical tape, and it stayed like that for 3 years. I finally went to cp[mike]'s house and fixed it properly... ground down the rough edges, painted the metal, and covered the sharpness with wire look (though vac hose, as mentioned, is probably better yet).
Originally posted by SMseagren83might not be the cleanest method, but enough banging and holes, possibly could work! i wouldnt do it that way....id use a dremel and some fiberglass reinforced cutting wheels and go at it, then take a grinding stone and smooth out the hole. then after that take some small vacuum hose, slit the hose in half down the middle ( not all the way through) and then line the hole with it. oh and u could use touch up paint and cover the RAW metal from the hole u cut before the vacuum tube....
Sean
