How to wire a ground wire...
    Hey guys,
    I purchased a ground wire on ebay the other day, click here to view it, http://cgi.ebay.com/ebaymotors/HKS-R...QQcmdZViewItem
    Any way this came without any form of instructions, can any one explain to me how and were to connect all the wires? i would greatly apreciate it...
    thanks
    on gas pedal, IMHO my ride looks awesome altough its 100% stock, its cleanliness and its frost white color are the only mods I need....
    Help me get a free xbox 360!!!!
    http://xbox360s.freepay.com/?r=31326965
    You just connect it on top of your ground battery teminal and connect the cables to any accessory that needs a ground. What are you connecting to it?
    "Saving The World, One Smile At A Time"
      Either bolt it down to something metal like the frame or body, or sodder it down. bolting makes it easier to remove if you ever get rid of it.
      (RIP)1993 LX Sedan
      Frost White Crew Member #36
      JDM Beating Stick Owner #1
      My (old) Ride
        Thanks, but I tought that in order to make the grounding effective and help the engine be more stable you had to connect it to specific points, I've got 7 wires, what would be effective spots to connect to?
        Is it that much effective?
        Thanks...
          Do I need to remove the old grounding wires to make it work? Has any one installed anything similar on his engine? if so tell how you proceed...
          Thank you
            All you gotta do is follow your stock ground wireing off the neg post of the battery and follow the 3 or so wires down to each point where they either ground to the frame or the motor and run your grounding system there... the extra wires can be grounded to other points on the body or things like foglights that would usualy ground to the body. However... I dont know how great of a idea it would be to actualy ground directy to the battery. EVERYTHING should ground to the body and the body grounds to the Neg on the battery. Dont mess up the flow.... Positive battery terminal--fuse--power draw then to the frame or body. 1 bad short and you could destroy a good battery or criple it to the point of making it worthless.
            Run those extra wires to other points on the body. Thats the only way that it would actualy provide a more stable ground for your car.
            Also i researched those heavy grounding systems made for the CB and wasnt impressed. Most are knock-offs that have name brands on them (spoon,hks)(these are just stickers slapped on cheap products). If you realy want to stablize your negitive and have a more stable positive aswell go with a dual terminal battery. They fit like a stock battery but have lower terminals aswell... they also give alot more cranking amps than stock does. You can run the back terminals to your fuse box and run your upper ones to your audio amp/fog or driving lights/ and any other accesorys you have. this is a good idea when trying to clean up a ratsnest of wires under the hood or a overloaded universal terminal connector so many of use have on the positive side of the battery. Watch as you headlights no longer dim to your music lol.
            Hope that covers IT ALL.
            I cant Slam further. The ground refuses to get any lower.
              Thanks, I will try it after work, I will let you know how things turned out and if it is really worthy...
                i think someone had a picture of this but i can no loner find it .
                hahahahah
