Roter removal???
    Roter removal???
    I bought some drilled and sloted street heat rotors and EBC green stuff pads and am having a trucking fun time getting the rotors off.
    I have a 5 pound slide hammer and I cant get the hub apart from the steering knuckle to change the rotors. I have the half shaft out and the four 10 mm 12 point bolts out of the back of the steering knuckle. IS THERE A TRICK TO GETTING THIS APART WITHOUT DISTROYING THE BARRING OR SEALS??????
    You just gota keep hitting it. It took a mechanic 4 hours to take my front ones off
    1991 Cb7 Coupe 5 Speed--SOLD
    2002 Nissan Sentra SE-R Spec V-- SOLD
    1994 Acura Legend GS
    Car Pics
      the previous poster is right. Front rotors are a big pain...i would say just bring it to a shop...cause you might destroy the wheel bearing while your doing it. Good luck none the less!
      Audi A4 2.8 Quattro Sport
        it took me 3 days to take mines off. plus many broken tools. one of which was an air compresser & impact gun
        93 Accord LX Sedan (sold)
          Here is a similar thread, with 3 links to DIY's
          http://www.cb7tuner.com/vbb/showthread.php?t=49912
            Of course.
            Longer bolts, screwed back in to the bearing, used to drive the bearing out of the hub.
            2003 Maxima SE Titanium Edition
            1993 Suzuki GSX1100F 136bhp
              using the slide hammer does work. not smart considering it runs risk of messing bearings up. but you take the 4 bolts on the face of the rotor off for some reason that breaks the tension where you can use the slide hammer. but the best way is to take the whole knuckle off and have a shop press the bearing out and the new one in. or if you work in a shop where you have access to a press do it yourself.
              always out numbered never out gunned..
                97~98 Acura CL Premium hub conversion is your answer!
                1st car: Frost White 1991 Accord EX sedan.. (Dec. 1999 ~ Jan. 2001) *Sold*
                2nd car: Black Pearl 1993 Accord 10th Anniversary sedan (Feb. 10, 2003 ~ Mar. 8, 2008) *Sold*
                3rd car: Frost White 1992 Accord EX sedan (Jan. 15, 2008 ~ Aug. 12, 2008) *RIP*
                4th car: Seattle Silver 1991 Accord EX coupe 5MT (Aug. 13, 2011 ~ Mar. 19, 2014) *Sold*
                5th car: Black Pearl 1994 Accord LX coupe 5MT (Mar. 1, 2014 ~ )
                  yes sir, acura knuckles ARE the way to go. Might even be cheaper than labor.
                  ...adjust accordingly
                    yups I'm soon to have the cl conversion soon myself. can't right to be able to change my brakes like the common folk do
